Can't get 100% throttle reading. 99... but not 100
brokenojoke
Post by brokenojoke »
I did the helms method of setting idle first of all.
Pulled off the iacv and set idle. Reset ECU and started it up. Idle reads .47 in logger at idle reading 0%. I read a couple of spunksters replies to others in this forum and he mentioned to try to get it to read .49 at idle, but it jumps to 1% and I get the up and down idle. So .47 it is.
At full throttle the logger reads 99%. I made sure it wasn't anything mechanical like the cable being misadjusted. I bottom out the gas peddle and the t/b is wide open.
Does the hondata run a different map at 100% than 99%?? Just wonderin if I'm missing any lost HP up there due to this.
I'm going to try t/b off my gsr and see if it's just the t/b.... any other ideas.?.?
This isn't a problem, 99% will be fine.
fonz600
Post by fonz600 »
There is an option to set closed and open throttle where you put the throttle wide open and click the button to say that is your full throttle and it'll save 99% as full throttle.
Sorry if thats a bit vague but not at a PC with Kmanager so can't tell you exactly what the option is.
I have 101% as full throttle :lol:
