No Vtec After receiving and clearin code 21 Vtec Spool Valve
AllMotorMatt
Post by AllMotorMatt »
Alright Scholars, I need some help!
After my car was left sitting for about 6 months I got it back up and about. Driving around that night I noticed the thermostat was sticking closed and causing the coolant the push back into the overflow and steam. Well I figured I might as well order an Aluminum rad, fan and new thermostat while I'm at it.
Threw the rad, fan and T stat in one night along with a heater hose which decided to crack at the same time (Lucky timing). After throwing everything in I start it up and it throws a code . At first it threw a code for a temp sensor which I forgot to plug in completely. After I fixed it and cleared the code it threw code 21 Vtec Spool Valve. There is an option in Hondata to disable the spool error check. I checked this and the code went cleared.
Now the only problem is that I have no Vtec. Initially I though I knocked a wire loose or something so I checked all wires and they are fine. I also checked the vtec solenoid which is also fine. I tried various things tonight to no avail. I tried setting the vtec temp minimum to something very low and still no luck.
If anyone has any other helpful hints that would be GREAT!
93 DA
Ls/Vtec
S300
Check continuity of the wire all the way back to the ecu.
AllMotorMatt
Tried that everything appears to be ok. Had my buddy come over with a volt meter too. Took the Solenoid off and checked the screen. No problems there.
93 DA
Ls/Vtec
S300
