95 lbs injector problems
redshade5
Post by redshade5 »
I have been fighting with this car for awhile now and not sure what to do. I keep having problems with the fueling. The car will run fine then when the cooling fans come on and the ecu sees the ELD the injectors won't react that well.this is a turbo car so can't afford to have it lean outon the top end. I have looked for a battery voltage offset table but didn't see one. Any ideas on how to deal with this? Btw I also tried using a fjo injector driver and it does the same thing.
