h22 turbo help...?
snwbrdrx19
h22 turbo help...?
Post by snwbrdrx19 »
hello everyone and thanks in advance. i just received my s300 and i need a base map for a:
jdm h22 turbo
stock internals
log manifold
t3/t04e
peaking 8-10psi
550cc injectors
cardinal811
Post by cardinal811 »
I have a map posted but it's running 1000cc's and at 17psi. Getter sleeve that block cause it will go boom real soon on a improper tune. You have a WB or a EGT? Going to need that too
snwbrdrx19
haha no i have a s200 now is tuned ok just too rich. i just got the s300 and want to tune it myself. i need a decent map to start off with.
snwbrdrx19
if i just change the injector sizing in the map will it run ok or will i have to tweak everything still?
just open the file your s200 was tuned with in Smanager (File, Open). It will convert it.
snwbrdrx19
how do i get that file if i dont have the tuning software. i have to go to my tuner or is there a way i can get it?
Contact your tuner for the file.
cardinal811
Contact Dave Blundell
