Gear Indicator
optix
Gear Indicator
Post by optix »
I'm running a USDM p28 with the latest s300, and I can't seem to get the gear sensor to function. It's always either in 1 or 5.
Is there something that I'm missing?
optix
Post by optix »
Hondata wrote:The ECU determines gear by speed/rpm. As long as your speed sensor is working and you enter the correct gear ratios, the gear will update as you shift.
So until the gear ratio input bug is fixed, there's no gear indicator, right?
You still should be able to enter the values manually.
optix
Post by optix »
Yeah, I did. I edited the calibration file with a text editor and got it worked out.
