intake temperature sensor(IAT)disabled,Will the vtec work?
adolfovalen
Post by adolfovalen »
I have a B20/VTEC b16 head,stock internals, ITR intake manifold, si tranny, 95 ex civic wiring harness, Hondata S300.
THE IAT sensor plug that comes with the harness dont fit the intake sensor, so i just left the sensor plugged to the intake, but not to the harness, the car revs hi but i dont feel the vtec kicking, will this be the cause of the vtec failing or should i check for other solutions,( new harnness, sothering a plug to the existing harness,or change the s300 settings?) THANKS. :D
You need to have the IAT sensor for it to run properly. YOu need to change the plug so that it will plug in.
adolfovalen
i already plug the sensor ......
Spunkster wrote:You need to have the IAT sensor for it to run properly. YOu need to change the plug so that it will plug in.
but nothing happened ? wich calibration should i use for this kind of setup?
can i use a the stock ITR calibration, the one that comes with the smanager? just to see if it works?
