PLX iMFD Gauges - Do they work with Kpro?
Slip_Angle
Post by Slip_Angle »
Can these configurable gauges be connected to kpro some way?
If not, is there a common/elegant solution that is used such as a carputer or something to have kpro active all the time instead of hauling a laptop in the car?
Thanks.
The PLX guages all work on their own with their own sensors. They do not get data from the ecu.
G_TypeR
Re: PLX iMFD Gauges - Do they work with Kpro?
Post by G_TypeR »
Slip_Angle wrote:If not, is there a common/elegant solution that is used such as a carputer or something to have kpro active all the time instead of hauling a laptop in the car?
I've seen some nice double din car pc's with touchscreen, usb ports and windows xp. I just searched for in car pc on google and found quite a few companies that do them.
