can someone over look this calibration?
laziebun
Post by laziebun »
setup is in the parameter under notes. It feels like im hitting a wall between 6/7 gran. maybe i have somekind of protection setup or somthing. But If someone wouldnt mind to overlook the whole thing for me would be great.
laziebun
Post by laziebun »
it did it again today.....let see....i punch it in first and then i second gear it went to only 5500rpm and the cell pop on as if it was the shift point, like it hit a wall or somthing. Can someone please help me out.
You have the revlimit set to 7022 and the shift light at 6510.
laziebun
Post by laziebun »
so what is that suppose to mean? i want the shift light to light up a sec before the rev limiter.
optix
Post by optix »
Try setting the shift light about 200 rpm lower than the shift point you have in mind. It'll take a bit for it to come on, so it'll be full-bore by the time you hit the target shift RPM. This is different on all engines, so just play with it.
laziebun
Post by laziebun »
It did it again, i was at half throttle and in 3rd gear and it was boosting up to 15psi when it hit 5500rpm and it just feel back. There was no bounching of the needle or anything. I tryed to mirror what i did, but this time it was fine and went to the rev limitor. Somone has to know what going on. Ive attach a new calibration with the new rev limit and shift light.
laziebun
Post by laziebun »
i just went out and this datalog. from warmup to cruise and full throttle. Still the same old problem.
you have a boost cut set at 15psi.
laziebun
Post by laziebun »
i guess that could be it, ill try it
