K20Z1 vtc question
RSXCBRLTR
K20Z1 vtc question
Post by RSXCBRLTR »
I just installed k-pro on my 06type-s and when i datalog my cam angles dont move. i clicked the tab on the vtc so there a check in the box, by clicking the tab on the vtc that enables the vtc right?
VTC should be enabled in the supplied calibrations.
What serial number is your KPro?
RSXCBRLTR
Post by RSXCBRLTR »
Well the vtc is enabled but it doesnt move when i datalog. and the check engine light is on, it say IAT low votage and when i clear the code it comes right back on.
vivalive
Post by vivalive »
i am having this problem also, i've have check the wiring, replace the sensor nothing slove the problems. Hondata never help me slove this problem.
RSXCBRLTR
Post by RSXCBRLTR »
Did you ever figure out the problem? I also change the 02 sensor with the 04 type-s before I put on the kpro and the minute I went online with the kpro the IAT cel came on. the other thing with Hondata I had on 03 type-s and bought a reflash and then upgrade to the kpro when it came out. I never had a problem with the ECU all motor but when I boosted the car I had a few tuning problems that I couldn't figure out. So I called hondata back when they weren't so big and a nice Australian man help me with all my problems and I was happy the car ran great. So now that I have another rsx I bought kpro again and this time know one wants to help me, calling them is pointless so I figure I could get some help here I guess NOT! I guess when you get SO BIG and you know that any engine swap requires kpro you could just sit back and count your money because you no longer care about customers!! I have recommended hondata to so many people and this is what we get in return. AWESOME!!!!
You were doing well until you called me Australian.
In order for us to help you, you will have to help us, including answering questions that we ask. Read http://www.hondata.net/forum/viewtopic.php?t=3629, and please include your KPro serial number. If you don't wish to answer, how can we help you? The reason we're asking for the serial number is so that we can establish if the ECU was prepared for an 05-06 RSX.
RSXCBRLTR
Post by RSXCBRLTR »
I knew I should have gone with British. Well anyways I believe I'm talking Doug if I'm not mistake, its been a while since I last spoke to you. As soon as I get home from work ill remove the ECU and send you the serial number and all the mods I have including what "rims" I got just kiddin.
vivalive
Post by vivalive »
its been more than half a year i havn't got the problem sloved. i was always ask to check the helm and check the wiring. well, it clear i checked before i ask hondata for help...
HONDATA
serial number of your K-Pro (4087)
- the calibration (k20z1 dyno tunning supply by hondata)
- a datalog of a problem (cam angle always at zero / Iat low voltage engine light
- what sort of vehicle you have (05 rsx type-s)
- what sort of ECU you are using (
- anything about the car which has been modified from stock which may affect the ECU ( injen cold intake, dc race header, hks hi power exhast
RSXCBRLTR
Post by RSXCBRLTR »
ok the serial # 5216
injen cai, dc race header,greedy sp.
From the oem wiring harness where does B17 go between the adapter and the K-Pro?
RSXCBRLTR
Post by RSXCBRLTR »
Would you happen to have a picture of the diagram so I could find B17?
Help, Contents, under reference.
vivalive
Post by vivalive »
oem b17 to harness b17
This is not a problem with the adapter harness then. Either the engine harness has been plugged into the wrong sensor or you have a short somewhere.
If the sensor was burned then you need to replace that and detemine why it burned.
vivalive
Post by vivalive »
it doesn't throw any code when i'm using stock ecu. its only kpro..
do u have the wiring pic for the harness? you could send it to shui_fai@hotmail.com
