KManager V.1.2.3.4 Beta
V1.2.3.4 (1 May 2008)
- Added boost control solenoid minimim and maximum duty cycle.
- Fixed Smooth function only applying to the 0 degree cam angle table.
- Added launch control and full throttle shift.
- Changed S2000 calibrations to use countershaft driven speed sensor by default.
Download here
The main change is to add launch control and full throttle shift. See the help file for more information.
Axix23
Post by Axix23 »
Cool.... any updates to indiv. injector duty/pulse soon???
Bflaker
Post by Bflaker »
For the launch and full throttle shift control, it talks about using the same clutch switch for activation. Do you actually need to add a micro-switch, or will it read off the factory clutch switch like the original launch limiter worked? Or did the factory launch limiter just go off of speed? The RSX does have a clutch safety switch, so why wouldn't it read from that? Sorry if this is a dumb question.
03' RSX Type-S
I/H/E/RBC/K-PRO/100shot/555R's
13.2 @ 109mph w/ 2.0 60'
kistian
Post by kistian »
Bflaker wrote:For the launch and full throttle shift control, it talks about using the same clutch switch for activation. Do you actually need to add a micro-switch, or will it read off the factory clutch switch like the original launch limiter worked? Or did the factory launch limiter just go off of speed? The RSX does have a clutch safety switch, so why wouldn't it read from that? Sorry if this is a dumb question.
the bold question don't work in my test
Bflaker
Post by Bflaker »
What do you mean exactly? Ellaborate
03' RSX Type-S
kistian
Post by kistian »
if you keep unchecked the new launch limitier (I've suposed it only works with the clutch switch), it don't limit the rpms (the factory limits don't work)
I don't test to enable the new launch limitier and test it such as old launch limitier
I think the old limitier was good but the new implementation sounds too like
poison
Post by poison »
awesome! thanks guys
-Brandon
'92 K20R EG SM/TTE
"Most amateur drivers go too fast in slow corners and too slow in fast corners" Emerson Fittipaldi
cranny
Post by cranny »
i tryed playing with it for the first time the other day , first time i came onto the car , as soon as i reached 7k , it limited the car even with the clutch out. so , unchecked now.
kistian
Post by kistian »
Hondata, is posible to have 2 methods of launch limitier? RPM based and clutch switch based and the user choose the bestone for their?
HONDA GHANDI
Post by HONDA GHANDI »
I got the boost/gear all setup in the Hellement last week, what a difference. Now I can actually get it to hook up in first gear. YAY. Thanks Hondata, I went from 14.0s on 6psi to 13.5s on 6 psi,8psi,10psi.
High altitude tuner www.tcperf.com
Bflaker
Post by Bflaker »
Figured out the launch control. Set your launch limiter to what ever rpm you want. Make sure the No Lift Shift isn't check marked. Then make sure the clutch switch is set to always on. Then set your maximum mph to whatever you want the launch limiter to stop working at. The only catch is that it works whether or not the clutch is pushed in or not. Just like the stock launch limiter. As long as you are below the mph you set the launch control will work. Once you go over that mph the car drives normal.
Here's a pic of my settings:
03' RSX Type-S
kistian
Post by kistian »
yes, I've thinking to try this, thanks for all Bflaker
kurt
Post by kurt »
Bflaker: Have you tried out the full throttle shifts yet?
Bflaker
Post by Bflaker »
No. I doubt I will. I'm about to install my dry nitrous setup and you don't want to use No Lift Shift with Nitrous. lol
03' RSX Type-S
the-anti-crack
Post by the-anti-crack »
i have a question about using launch controll. i have a k20 swapped eg civic. i have the 1.2.3.5 version. all wiring for the stock clutch switch is there. i havent touched that.
i used the hybrid racing conversion harness. every thing is running well.
i just dont know which setting to use for my clutch switch so i can actually use my 2 step. which setting should i use? do i use the "always on" setting? do i need to wire in a new switch? and what is the check box that says "invert clutch switch" for?
thanks guys!!
p.s. i live this k pro system. i havent used a hondata ecu since i had a turbo b16 with an obd-0 stage 3 ecu!! many years ago!! its good to be back in the game.
