plx sm-afr voltage offset
WTMRACING
Post by WTMRACING »
does any one know what the voltage offset is for a plx sm-afr?
Voltage offset will vary from vehicle to vehicle. You will just have to experiment with values until you get the display to match the PLX display.
sql_civic
Post by sql_civic »
Just an FYI my offset using this same setup was -.25V.
Yours could be different. Once I made this setting, then the datalogged values matched my display.
WTMRACING
Post by WTMRACING »
Thanks mine turned out to be -0.1
