can someone please take a look at this calibration?
allmotorh22a
Post by allmotorh22a »
for some reason it sputters when i try to run this calibration.. it was from a tuner , it was suppose to b my tune but for some reason its acting up thanks
Was your car tuned on the dyno by this tuner? Have you contacted the tuner about the problem?
allmotorh22a
yes i have.. this was the only map he had saved on the date of the dyno for me.. unless he saved it under something else becuz looking at the map again and comparing it to a stock h22a map.. it looks exactly like a stock map so therefore i feel that this was just a stock map to get the car to drive on the dyno and the tune is lost somewhere...
setup is stock h22a with ported head and rocket motorsports h24x cam
EconoBox
Post by EconoBox »
This map was for the dyno tune on my H22a with a stock bottom end and a Gude head package (Port, polish, and dual springs and retainers). Also stock cams. Has 390cc injetors on the map which you may want to change.
Ran great for me. Made 186Hp and 147lb. Was tuned By John Vega of Phearable.net
