datalogging problem wit new smanager software
allmotorh22a
Post by allmotorh22a »
i cant seem to get datalog to work on the new software.. even the tuner was puzzled.. on his laptop wit v1.3.3 it works fine.. but on my laptop wit the newer version i cant log nothing.. y is that? thanks
allmotorh22a
still the same!!! wut is the problem??? i cant seem to datalog :cry:
allmotorh22a
damn no one on here can help out about this dataloggin problem?? doesnt that just kills the whole purpose of paying for the s300 unit?? comeon guys help me out here its getting on my nerves not being able to datalog
Have you uploaded the calibration using the 1.3.5.0 version of the software? WHo socketed the ECU? Has J12 been cut on the ECU?
allmotorh22a
yes i loaded the calibration with the new software.. hondata socketed the ecu.. its funny cuz it was dataloggin wit smanager v 1.3.3 when i was at the tuner.. got home loaded the map off my laptop using v1.3.5 and it'll datalog for like 30 secs and freeze up
If you go to ECU information (blue "i" button) what does it say for the firmware version?
allmotorh22a
1.04
What happens if you go to File, New and create a new base calibration and upload that with the key in just the on position but the motor not running and you try to datalog?
allmotorh22a
it'll show the sensor voltage n all it'll work like that but once u start the car it starts trippin out
ITR 1102
Post by ITR 1102 »
allmotorh22a wrote:it'll show the sensor voltage n all it'll work like that but once u start the car it starts trippin out
Did you make sure that onboard datalogging is disabled while datalogging from the computer?
If not, that will **** it up like you are stating.
allmotorh22a
yes onboard dataloggin is disable.. thanks for the input tho
If it datalogs fine with the car not running then you have an interference issue with the ignition. What spark plugs do you have? What ignition system are you using? What plug wires are you using?
allmotorh22a
stock ignition system ngk spark plugs, ngk plug wires
Are the plugs non-resistor or resistor type? What part number?
allmotorh22a
ngk:
stock no. 5030 BCP7ES
