Hondata boost control
rudebwoy
Post by rudebwoy »
I am contemplating on using the boost control, I so happens to have all parts needed to do this conversion PWM components , boost solenoid etc. I currently have a greddy profec b with a brand new solenoid, I plan to use the greddy solenoid, I've seen it done before,but it if fails I also have a MAC solenoid but since the greddy is already installed I will use it. anyways I've researched everything but haven't found anything on HI/LO boost selection, I hope to use my profec remote switching system as my hi/lo boost switch.
I have an idea but just want to be sure.
so to install I assume one wire of the remote transmitter will go to ground, and the other will connect to pin B5 for example?
Since I'm not familiar with how the Greddy controller works, I cannot say how it should be connected or work.
rudebwoy
Post by rudebwoy »
well in general how would it be connected with the hondata boost solenoid?
the greddy have 2 wires just like the MAC. and I saw someoone used it before.
In Smanager, go to Help, Contents, and search for "boost control solenoid installation"
rudebwoy
Post by rudebwoy »
I'read all this but it still havent answer in specific what I am trying to find out.
I wanna use an external switch to switch between high and low boost levels.
should intall one lead of the switch to ground and one lead to pin b5?
yes
rudebwoy
Post by rudebwoy »
thank you sir
