More than 1 rev limiter.
RickyLee53
Post by RickyLee53 »
Could the S300 be made to have more than 1 rev limiter?
I don't want to change the rev limiter in every gear, just 4th for drag racing. As i'm hitting the limiter just before the line. I want to up it 200-300 RPM's however i don't want to put this strain on the engine in all gears, and miss shifts etc.
Could the program be changed so this is possible?
No it cannot be changed like this. Just set the shift light where you need to shift and set your rev limit slightly higher so that in 4 gear you can just keep going.
RickyLee53
Spunkster wrote:No it cannot be changed like this. Just set the shift light where you need to shift and set your rev limit slightly higher so that in 4 gear you can just keep going.
Shame, but the problem is, when the car spin's i usually let it hit the limiter so i set it lower.
Set up a nitrous output for maximum ignition retard the igniton below 3rd or 4th gear and 500-1000 rpm before the rev limiting. This will soften the rev limiter in the lower gears if you're getting wheelspin.
