Getting wierd signal to injectors
gorillahumper
Post by gorillahumper »
I have a 88 civic with a d16 turbo biult and s300. My injectors are dsm's. Im having problems with the signal to the injectors. My ignition system is working great. First time it happened it wouldnt start until i turned the key on and off a few times. When it finally started it ran perfect until turned back off. I played with it for a few days and left it alone for a week. When i went back to it it started and ran fine, I started it and cut the ignition off completely 10 times, left it for an hour and it wouldnt start back up. I just swapped the distributer and that didnt change anything. I have s300 and have gone back to stock ecu and it does the same. It started and shut back off wouldnt start again. The only thing it does consistently is when on the throttle it will bump 2 times one after another then skip 2 cylinder. Fuel pressure is good, the resistor box has been swaped with a good one. I am getting good resistance to the injectors. I really dont want to take it to a mechanic, ive done my complete biuld by myself and it feels good being able to fix things myself. Any help would be appreciated. THANKS
