Weird A/F datalogging?
EITCP
Post by EITCP »
K-pro
K20A2 euro civic type r
put vehicle in open loop
cut ELD wire, connect white wire from plx to ELD wire to the ECU and i went to options>settings>wideband input>select plx M series WB and ELD pin selection. i got correct AF ratio in display parameters . ok, good so far. Then i tried to datalog this AF ratio in "fuel adjustmens" target lambda but i got all cells marked as 0 adjustments. I went to to lambda log and i see all values in complete map 14.70 which isn't right. I tried to go into full throttle run and i got dispaled 13 AFR but in lamba log i see value 14.7. Why? has anybod any clue? Am i doing something wrong ?
Austrian Type-R
Post by Austrian Type-R »
I've exact the same problem!
Did you found a fix for this?
Or Hondata!? Can you help us out!?
THe ELD input is for Datalogging and display only and will not work to run closed loop or use the target lambda/lambda/fuel adjustment tables.
