noob question, engine management light with de-cat
consett_chris
Post by consett_chris »
right guys i have a 2002 civic type r
it has already got kpro fitted
but i dont have the wire to connect it to my laptop so my first question is what type of wire do i need to connect it to my pc??
any links would help
also car has just had a de-cat fitted with a tanabe system and a gruppe m air filter
no my engine management light is on all the time because of the cat being removed, was told i needed a 02 simulator?
but then was told if i had kpro i did not need a o2 sim as there is a way of fixing it through kpro ? any ideas
You can use any standard USB cable.
To eliminate that error code you must disable emissions error checking.
consett_chris
but the connection on my ecu does not look like a usb connection?
how do i disable that
I assure you it uses a USB cable.
Look in Misc under Parameters.
