Hondata S300 and 2.5bar map sensor question...
champlsinteg
Post by champlsinteg »
I just had my car tuned for mostly WOT on the dyno. I have the motorala 2.5 bar but the thing is that the Neetronics 2.5 sensor was selected in hondata and tuned on that. I was going to play with the fuel tables in partial throttle and noticed that that sensor was selected. The car idles at around 14.7 afr but when I change the map sensor to the motorola the afr goes from mid to low 10s.
My question is...Can I just leave it with the incorrect sensor setting in hondata and just tune the afr for partial throttle since WOT afr is already tune with? Or do I need to go back to the dyno and retune with the motorala?
You should have the correct sensor selected and it should be tuned using the correct sensor. Using the incorrect sensor will make al your map readings be off and even if the tuning in one area is correct you will more than likely be off in most others.
