Gauge Temperature problem
Mcapela
Post by Mcapela »
Hi there
sorry for my question but i'n new in this subjects
i have i European Honda Civic Type-R EP3 with K20A2, i have buyed a few days to replace my OEM ecu a PRB ecu,
i have erase all the ecu and upload the K20A2 civic type-r factory calibration include in CD rom of Kmanager
at here all ok, but after that i have upload a K20A2-RSX-stock and the tunned too calibrations and after that the gauge temperature do not work
somebody can help me ?
thanks
What version of software are you using from Help, About?
Mcapela
Post by Mcapela »
hi there
the version of stware is 1.2.3.5
thanks
Try downloading the software again from our website. After installing, go to Online, Tools and clear security. Wen that is done, close the program, reopen it and upload a fresh calibration from File new. Your temp guage should work. This has been tested. The only other reason it would not work is that you may have mis-wired something when changing the wiring for the PRB.
Mcapela
Post by Mcapela »
Spunkster wrote:Try downloading the software again from our website. After installing, go to Online, Tools and clear security. Wen that is done, close the program, reopen it and upload a fresh calibration from File new. Your temp guage should work. This has been tested. The only other reason it would not work is that you may have mis-wired something when changing the wiring for the PRB.
Hi there
thanks for you quick answer, i'm going try that, but i dont have chanhge nothing in wiring car, i have to change the harness wiring ? what ? can you help me please ?
Another question if you can help
I have buyed the interface to connect my PRB ecu to AIM MXL PISTA
and i have some parameters i can understand the values.
for example for teh HONDATA_SPEED and HONDATA_GEAR the values 80 Km/h and 6 gear engaged but THIS with car stopped in neutral position.
and can you please tell me the values of the Vtec pressures and solenoids ? what are the normal values and abnormal
thanks for all
with my best regards
