need help with injector size.
splmike15
Post by splmike15 »
stock b16a garret T04E fmic, walboro 255, 10lbs. i had dsm 450's but was told that they burn up hondata. so would 660's be ok so i don't have to buy small injectors, then when i build this buy bigger injectors??
8112
Post by 8112 »
660 would be fine for what you got
Are the 660's peak and hold or saturated? If they are peak and hold you will still need to use a resistor box. RC makes 650's that are saturated and do not need a resistor box (available through any Hondata dealer).
justin
Re: need help with injector size.
Post by justin »
splmike15 wrote: i had dsm 450's but was told that they burn up hondata.
Burn up Hondata? What does that mean exactly?
I used 450's on my old stage4 hondata years ago, and am getting ready to use them again on my s300.
Justin
