Startup Issues...Please help ---->>Datalogs Included
PapiTuyo
Post by PapiTuyo »
Hello,
I recenly swapped an RBC manifold onto my k24a1 k20z3 hybrid. While doing so, I also swapped the aftermarket clutch for an OEM unit.
I unfortunately mixed the TPS and MAP sensors on the initial start up. It ran very rough and I caught my mistake and corrected it.
Now the car won't start up. I have verified that all fuses are working. My fuel system is functional, as Ive tested the pressure. I pulled the spark plugs and replaced them with new oem units. My TPS unit is working, as Ive verified pressing the gas pedal and datalogging to ensure proper reading. It reads a couple of degrees high, but that is a throttle cable issue.
I am lost on what could be going on. I made no major engine changes. My only guess is that the map sensor may have been permenantly damaged during my start up attempts.
I have attached two datalogs for your review.
"Does not start" is a series of attempted start ups.
"again" is a single startup with datalogging initial sensor readings.
Hopefully one of you guys can help me out. I am lucky enough that I can ride a bicycle to work (30 min biking), but I would muuuuuuuuuuuch rather be driving my car, especially under this Florida Heat.
teh leet ep
PM ME FOR BEST PRICE ON K24A2 SWAP :)
Status: K24Z3 Hybrid rebuild in progress.
Try your map sensor in someone elses car or use their map sensor to see if there is a problem with the sensor.
