S2000 K-Pro 02 sensor high voltage?
Garrett_si
someone know why after the s2000 k-pro installation the CEL code P0132 02 sensor voltage high light up?
Select 'Use Secondary Oxygen Sensor for Primary'. is done
Garrett_si
- serial number of your K-Pro : 03003322
- the calibration (as an attachment)
- a datalog of a problem (as an attachment)
- what sort of vehicle you have: S2000 2.2 2004
- what sort of ECU you are using: PRB with S2000 K-pro
- anything about the car which has been modified from stock which may affect the ECU (don't include what sort of rims you have nor stereo etc).: no modification that could affect the ecu
- a specific description of the problem : the code P013202 sensor High voltage light up[/b]
Garrett_si
Garrett_si
Garrett_si
Garrett_si
After a few trips back to my tuner I continue to throw the same code related to the o2 sensor. There is another local Greddy boosted w/K-Pro and the only difference between his set up and mine is the IAT sensor. When he bought his K-Pro it was not required to swap it out, when I bought mine about 1.5 mths ago, Hondata's K-Pro S2000 link on this site added it to their list of additional parts and called for a new one. I am swapping it back on Monday and will see if I have the same problem.
Anyone from Hondata know what may be causing this?
Interesting? So this has been a common issue? Will you be notifying us via this thread or an e-mail? When do you think you will have this fix ready?Spunkster wrote:We are looking into a permanent fix for this and will update you when we have a resolution.
Do you know why it only seems to be happening with the newer users like myself?
Thanks for responding.
