S2000 k-pro Honda parts list...
Garrett_si
Post by Garrett_si »
I installed a S2000 k-pro this weekend
the valve cover don't look to be required
the only difference notice between the 2000-05 valve cover and the 06+ one
is that the holes for the cam exhaust on intake side is not there....
the PCV valve is not required too
Changing the valve cover is not optional. You must change this or it will not work as the cam position sensor will not read.
Garrett_si
Spunkster wrote:Changing the valve cover is not optional. You must change this or it will not work as the cam position sensor will not read.
the position is different?
