High speed tables inop
Robs97'SH
Post by Robs97'SH »
I've been unable to tune my high speed tables even though they are working. I have secondary on (always) , the check mark is checked . When I click the high speed fuel or ignition, I see the table for a split second then it goes back to low speed. I've tried clicking it in open loop and closed. Any help on what I'm missing would be great.
I think you are confusing secondary tables with VTEC tables. First you should disable the secondary tables and not have them set to always on. Next if you are datalogging and have it set for the tables to follow VTEC under options then when you are not on the high cam you wil be unable to make changes to that table. To bypass this simply uncheck the tables follow VTEC option.
Robs97'SH
Post by Robs97'SH »
Thanks man, ya follow VTEC is checked. See my problem is that when I get into boost. I get this bog or it might even be protection mode at about 5k. I'm not running alot of boost about 7lbs but I can only get like 5 at the moment due to this bog. Its not fuel cutting out but either timing or fuel mixture. Any other bits of advise?
impossible to say without the calibration and a datalog showing the problem.
