Adjust mph to tire size??
civicbynature
Post by civicbynature »
Here's a question I've was just pondering. Is there a way, OR, could there ever be a way to adjust the mph read out with in smanger. I know you can't adjust the one on the dash cause it's cable driven but, I ask this because i want to use smangers display as a dashboard. Due to tire sizes it's always off. Now i have ways of clocking my car. so I know how much it needs to be adjusted as per tire diameter.
Thanks in advance for any help........ :?:
Project Diamond: 93' Coupe B16a N/A
Project Frankenstein: 91' CRX-SI H22 N/a
Project Master blaster: 96' Hatch K-Series
Project ISIS: 92' Hatch D16y8 WIP
There currently is no way to adjust this. I do not know if it is something that is possible.
Tchleung
Post by Tchleung »
Wouldn't be 100% accurate, but why don't you pick your tranny in the gear ratios section, then manipulate the ratios so they are more "equal" with the enlarged tire size.
kesnut
Post by kesnut »
Spunkster, didn't you guys have this in the old version back in the romediter days?
