J&S Classic Install Help
ElectronMan
Post by ElectronMan »
I picked up a J&S Classic recently and I wanted to see if I could get some help installing it with the Hondata. I have a Stage 2b and a P28 ECU on a '99 Civic SI.
Can I tap into the stock knock sensor? or do I need to install another one somewhere?
info for install
You can use the stock knock sensor, just tap into it at the ECU. Install it just as if you had a stock ECU. Make sure you get a good power source and good ground oo it will cut out while driving or with any bumps.
