Need Some Info From People That Know What there doing
itszachyo
Post by itszachyo »
K i got a 94 honda del sol and it's had a engine swap to a JDM b16a2 vtec. but the ecu was never changed. so i want to change it to one that would make it perform the way it should, and have that ecu capaible with the hondata s300. Any one out there that can help me out?
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ).
