Will crusie work if I set FTS and LC to my service connector
TwoKSiR
Post by TwoKSiR »
If I set my launch control and full throttle shift to activate when the service connector is jumpered will my crusie work then? From what I have been reading the reason it's not working is because FTS and LC are using the same clutch switch. I drive on the highway alot and really like having my cruise.
If that wont work is there another way to get my cruise to work and still have those 2 features?
You will have to put a jumper on the connector that was connected to the original clutch switch. This will allow you to use the cruise, but it will not shut off if you use the clutch.
