whenever trying to download calibration from ecu = error
imratedpg
Post by imratedpg »
as above, whenever i try to download the calibration from the ECU it comes up with 'floating point not divisable by zero'.
my friend who originally calibrated the ecu had no problems with downloading etc.
following the format of posting up a problem:
- the calibration (as an attachment)
n/a
- a datalog of a problem (as an attachment)
n/a
- what sort of vehicle you have
93 civic eg hatch
- what sort of ECU you are using
obd2b ..will find out tomorrow mornin
- anything about the car which has been modified from stock which may affect the ECU (don't include what sort of rims you have nor stereo etc).
h22 conversion
- a specific description of the problem
when do the following: click on 'online' then click 'download' then click 'it goes 0-100% then a prompt says 'floating point division by zero' or something like that.
mates laptop (vista) works perfectly ( he did the original calibration)
i tried both my laptop (Vista) and my dads( XP) and same error!
looked through all the help content that came with the smanager program and flicked through what the search command on this forum spat out and still cant figure.
i think it has something to do with display but i cant figure out what?
thanks in advance.
raymondm2007
Post by raymondm2007 »
man i just got the same thing today :x i can download nothing..
What version of software are you using from Help, About?
imratedpg
Post by imratedpg »
sry, version 1.3.6.0
when i go help -> check for updates it says: 'smanager is up to date (V1.3.6.0)'
Try closing all windows inside Smanager before downloading the calibration. If you still get an error trying to download, then unfortunately you will not be able to use the calibration in the ecu. You will have to get the calibration from your tuner. If this is not possible, then you will have to go to File, New and start with a new calibration. It is important to always keep a copy of your calibration in a safe place, even if this means emailing it to yourself and keeping it in hotmail so you can access it anywhere.
imratedpg
Post by imratedpg »
why does this occur?
Stokes
Post by Stokes »
this is a major problem that needs a fix asap i have a 600 ecu that i cant tweek my settings on
