K-pro problems
skoolnu
K-pro problems
Post by skoolnu »
- 37820-pnf-a03
2091-303823
2002 civic si
JRSC w/ 3.8"
intake
buddy club race header
full exhaust
650cc injectors
k-pro
MAP will not read boost, and A/F is stuck at 10.70 on datalog graph... but while datalogging, on the display screen shows the A/F reading.
Are you using the MAP relocator provided by Jackson Racing?
skoolnu
Post by skoolnu »
i am using one i got from inlinefour.
If you are not seeing boost, it sounds like you don't have the map relocator installed correctly.
http://www.hondata.com/techrace_jrsc-install.html
skoolnu
Post by skoolnu »
"You will then need to connect the vacuum line from the MAP relocator to where the Jackson Racing TFI vacuum line was attached on the manifold"
do you have a better pic of how this should be?
We only have the pictures on the website. If you are unsure of where it should connect, you should contact Jackson Racing.
