cycle is high and getting low boost
jbcivic03
Post by jbcivic03 »
I recently hooked up my hondata boost solenoid. Its set on 30% duty cycle and only getting 11.5 psi. Does any body know what the problem would be?
mnjdmek4
Post by mnjdmek4 »
are you running the stcok map sensor? you only get about 11psi for the stock map sensor.
When reporting any s300 problems, please include:
- the calibration (as an attachment)
- a datalog of a problem (as an attachment)
- what sort of vehicle you have
- what sort of ECU you are using
- anything about the car which has been modified from stock which may affect the ECU (don't include what sort of rims you have nor stereo etc).
- a specific description of the problem
says Admin
jbcivic03
Post by jbcivic03 »
Its currently running a gm 3 bar map sensor. Its p72 ecu. civic with build gsr with sc61 turbo. I would have to see if my tuner can load the calibrations. Dont you find it odd for that cycle number and that much psi out of it?
Duty cycle all depends on your setup...each car will be different.
