can not install rom editor 4
ROM Editor 4 tuning software questions and answers.
japerformance
Post by japerformance »
hello i cant seem to install the software on the laptop, i have downloaded it from the site under downloads and saved it in my documents then when i run the application i get the error which i have attached if i click retry it just keeps popping up and if i click ignore the software wont work and if i click abort it simply doesnt install anything. Any ideas spunkster
It sounds like you already have Romeditor 4 running. Close it then try reinstalling.
japerformance
no i dotn have any hondata software loaded on the system. after i tried installing it it made all the folders etc so i went into control panel and removed everythign and tried again. no success where can i download rom editor 3 to see if that installs
Uninstall RomEditor4, then check under Program Files for any remaining installation directories. If there are (I see you were installing to a non-default directory), then check that none of the files in these directories are read only. I'd also recommend sticking to the default installation directory.
japerformance
ok found the problem there is a file called win32 in the install and mcafee is picking this up as a virus and deleting the file if i unprotect my pc it istalls with no problems.
now that i have it installed and the s200 fitted to the car i can get communication and i am using the keyspan 19h adaptor any help appreciated.
Have you purchased Romeditor 4?
