AC switch hook up for datalogging
mij_nagrom88
Post by mij_nagrom88 »
was hoping to get an answer on how to use the ac switch to turn on the datalog.i have no ac but the wiring is still un cut.thank you
You wire a switch to the input and no longer use the rest of the ac wiring. If you are unsure of exactly how to wire this in, you should contact a shop familiar with wiring as improper wiring may damage the ecu.
