PND-A08 ECU insetad of PRA [European EP3]
eTiLiKo
Post by eTiLiKo »
On a European EP3,that mount from the factory a PRA ECU,can be mounted a PND-A08 ECU with a Kpro on it?I mean without harness mods.
Is it a free-issues operation?
Thanks :wink:
eTiLiKo
Post by eTiLiKo »
It is sufficent to have the pinout of hte PND-A08,but i havent't it.
This will not work properly without making wiring changes and installing a wideband o2 sensor.
eTiLiKo
Post by eTiLiKo »
Ah,ok!
Can you help me with the wiring changes?I already have this ECU with the Kpro on it,so I have to mount it. :roll:
Thanks a lot :wink:
eTiLiKo
Post by eTiLiKo »
Thanks a lot,I know this page.
I had miseunderstood : I believed that I had to make further changes than those for the o2. :oops:
So,when I make the o2 wiring modify all works fine?
eTiLiKo
Post by eTiLiKo »
And another question : the new O2 sensor [36531-PRB-A01] have trhe same connector of the "old" primary narrow?
I believe the connector is the same, but since we do not have these cars in the US I do not know for sure.
eTiLiKo
Post by eTiLiKo »
Can be another solution to unsolder Kpro from PND and mount on the PRA?
Garrett_si
Post by Garrett_si »
the k-pro is not soldered
but it couldn't be put into another ecu since the board need modifications
eTiLiKo
Post by eTiLiKo »
Yes,i want to say replicating all the necessary mods to the PRA board.
eTiLiKo
Post by eTiLiKo »
Spunkster wrote:I believe the connector is the same, but since we do not have these cars in the US I do not know for sure.
Yes,the connector of the wideband is the same of the narrowband.
I have mounted it and made the mods,the car start with no problem 8)
