timing issue with s300
Posted: Mon Jul 07, 2008 4:54 pm
93 civic ex with built d16 engine, stock timing gear and no major material decked from the head or block. when timing the car i can only achieve 9degrees with the distributor fully advanced. i've set low vtec map to 16 at all points, uploaded map, jumped out CEL at the blue two connector next to ecu, verified timing belt was not off, verified timing was steady when car is revved up, but 9degrees is all she's got.
anyone with similar issue with SOHC?
