Problem of Kmanger 1.2.3.5 or bad sensor ??
rikitaun
Post by rikitaun »
If you see my log, at second 10 (and more) you can see the CAM angle at 35-38 degrees when the kal says 30 degreees :shock: :shock: :shock:
It's a problem of kmanger 1.2.3.5 or VTC sensor/CMP sensor is bad ???? :evil: :evil:
You have a knock error. You need to either fix that or disable the knock sensor.
rikitaun
Post by rikitaun »
Spunkster wrote:You have a knock error. You need to either fix that or disable the knock sensor.
sorry but my english is very bad... :(
I know that my Knock sensor is broken :( and out of engine,
I unchecked this option on KAL...
more info: I have a PRB Ecu, 4-2-1 Exhaust Header Zspeed, Toda A3 cams, Intake Header RBC....
rikitaun
Post by rikitaun »
At last!!!
The problem was a TPS sensor ... y put new TPS sensor and the car runs fine.... :wink:
