data logging stops after a short time
EGHATCH
Post by EGHATCH »
so whenever i datalog this particular car, datalog stops after about 10seconds. sometimes even less.
like its getting disconnected, you cant datalog, upload cal, etc.
but when i pull then plug in the USB again, it will start to connect again.
then same cycle happens. datalog for short time, disconnected again...
car is a swapped k20a. i have no problems datalogging other customers.
what could be the problem with the car? help!
you wont learn until you actually do it.
http://www.hondata.com/techksparkplugs.html
This is the most likely cause of the problem
EGHATCH
Post by EGHATCH »
wow! it worked! thanks so much.
i used iridiums ik22 and it datalogs perfectly now.
