s300, sensor readings not working in s manager
sm61
Post by sm61 »
96 gsr, internaly stock,JRSC 6 psi, p28 s300 socketed by you guys, plx m300, rc440's,walbro pump,stock map sensor with map bypass,oem ngk plugs. Downloaded the most recent s manager. Loaded your b18c supercharger calibration. Car fires up fine, idles perfect, good throttle response. Whats wierd is if I click on the sensor window, they all show like they arent working. IAT shows zero, map is fixed at 24.5, rpm shows zero, etc. Any ideas would be apprieciated, thanks.
Have you clicked the datalogging button to actually begin datalogging?
sm61
Post by sm61 »
Spunkster wrote:Have you clicked the datalogging button to actually begin datalogging?
No, I just assumed when the engine is running the sensor readings would show up. Sorry, I am a newb to hondata. Thanks for your continued help though. :D
