A/F values never match A/F CMD values...
Conquistadore
Post by Conquistadore »
Hello,
When I look at any of the datalogs of mine, I see that the A/F values never match the A/F CMD values. In other words the A/F is always 14.7:1.
I tried:
1. Adding more fuel to columns 7-10.
2. Changing the Lambda Overlay Settings.
I also tried to add more fuel according to the Fuel Adjustment recommendations. For instance:
I started the dataloging then, at the third gear, I went from 2000 RPM to 8200 RPM, drived back normal and stopped dataloging, added 8% more fuel to columns 7 and 8 according to the Fuel Adjustment recommendations. Uploaded the new calibration and had another test drive. When I checked the Fuel Adjustment recommendations it was still telling me to add 8% more fuel.
Please advice.
Thanks and Regards.
2002 Euro Civic Type R
KPro (SN:05506, HW Ver.:2.16, FW Ver.:2.02)
Hondata Heat Shield Gasket
BDL 66mm Throttle Body
Fujita F5 Cold Air Intake
Toda Headers
Mugen Power Mid Pipe and Twin Loop Rear Silencer
AEM UEGO 30-4100 Wideband Controller
The PRA ecu does not have a wideband and you cannot tune using the readings from the o2 sensor.
