Help In S300 Engine Code #3 Bar map sensor error
yillo
Post by yillo »
Hello to everyone I am new but I have a problem with my hondata S300, if I have a civic 93 turbo and after a while I turn the car running the engine check and I get the code # 3 and the hondata tells me 3 bar map sensor Error can help me I'm going crazy. forgive my English is not very good. Thank you :( :(
You will have to follow the factory service manual (Helms) for the error code you are getting. It has all the troublshooting info.
TTR
Post by TTR »
What 3 bar map sensor are you using, and what calibration are you using? If you are using a Hondata 3 bar you have to use the Motec calibration, using the MSD calibration will throw an error on decel in some cars.
yillo
Post by yillo »
I have a map sensor bar 3 MSD and that is that gives me the error :(
TTR
Post by TTR »
Try using the Motec 3 BAR calibration
