gm 3 bar map
Posted: Fri Aug 01, 2003 8:47 am
by hack
so if jeff atwood is correct then moving the fuel to match the 'actual' boost which corresponds to voltage lower than we expect will yield the right mix. YES ?
3 bar MAP sensor
Posted: Fri Aug 08, 2003 9:16 am
One comment we wish to make is that we do not use GM 3 bar MAP sensors. The MAP sensors we sell are sourced from MoTeC. They appear to be the same part as the common GM MAP sensor (made by Delco) but we can't tell if they are internally the same.
