how to set s200 back to normal
bgpmpn
Post by bgpmpn »
so tonight i was trying to set my launch control on my hondata s200 and it didnt work i used my cruise control switch and now its all screwed up some how it raised my fuel presser i have a shift light that i dont want and im just worried that i did something bad i just want it to go back the way it was when i got my car if anyone can help that would be great thanks
bgpmpn
You can download the instructions for the s200 at http://www.hondata.com/downloads/S200%2 ... 0Guide.doc
There is no way that the Hondata could change your fuel pressure, as the ECU has no control over that.
bgpmpn
Post by bgpmpn »
it was just wired cause i changed my fuel pump to a high volume and my gauge under my hood was going crazy before i changed the pump it was at 41lbs now its at 48lbs so i dont know
bgpmpn
bgpmpn
Post by bgpmpn »
can you tell me if my hondata s200 has launch control in it the serial number is 4273 thanks
bgpmpn
yes it does
bgpmpn
Post by bgpmpn »
thanks i called hondata and they said the same thing
bgpmpn
