Question Regarding Installation
Posted: Fri Aug 01, 2003 11:29 am
I'm about to buy a used Stage 4 with the hopes of learning/starting to tune (at a cheaper initial price) and eventually upgrading to an S200. What I'm interested in are the components that install into the ECU. I've got a P72 ODB-I ECU.
1. Is there a specific D-latch chip that I should buy? The 74HC373 chip has multiple vendors and configurations. I'm assuming 20-pin DIP, but most of the ones I find are 6V max. Should it run on 12V? Or is there a step down converter on the ECU main board?
2. The ceramic 0.1uF caps can be any voltage range? Or should they be above a certain voltage? I'm assuming these are just bypass caps?
3. The 1.1Kohm resistor (R54) does not need to be installed on a P72, why? What is the function of this resistor on the other ECUs?
4. CN2 looks like it should be a simple Molex part. MTA100-4. Is this true?
5. Do you have a PN for the ROM socket? Or any 28-pin ROM Socket will fit? 0.1 spacing?
6. I read the ROMEditor 2.5 Manual and it says any EPROM similar in performance to the Shand Thomson ST M27C256B-15F1 should be fine. Does the ATMEL have to be 150ns? Can it be less? The one ATMEL EEPROM AT29(27?)C256 at 150ns looks like it might go obsolete. Is there a replacement or alternate vendor?
Thanks!
Thanks!
