S200 To S300....
*E_R_P*
S200 To S300....
Post by *E_R_P* »
So I Have A S200 And Since I lost My Datalogg Cable and I Cant Get It Anywhere, Im Going To Upgrade To S300... My Question Is If THe Current Tune [Turbo] Profile Can Be Transferred And Work Perfectly On The S300 .... I Just Retuned The Car So Im Not Looking To Retune Again When I Get THe S300 As I've Been Told.... Hope I Can Get Some Answers..
Thanx!
IT should run the same, but you should double check the air fuel readings.
*E_R_P*
Post by *E_R_P* »
Spunkster wrote:IT should run the same, but you should double check the air fuel readings.
ok, now do i have to use Resistor plugs with s300??.... car was tuned with 9's non-resistor.... and what do i need to transfer my profile from the s200 chip to s300???...
You should use resistor plugs in any vehicle with any form of electronics.
*E_R_P*
Post by *E_R_P* »
Hondata wrote:You should use resistor plugs in any vehicle with any form of electronics.
ok... so how about transfering the profile to S300 From S200 chip??....
thanx...
IF you have the bin file for your s200, in Smanager go to File, Open and locate the bin file and it will convert it for you. Do not make any changes to the injector size even if it does not perfectly match the size you actually have.
joeb
Post by joeb »
I did exactly this on my turbo integra last year . It works perfectly and the tune should remain identical . Mine was spot on at the dyno .
*E_R_P*
Post by *E_R_P* »
joeb wrote:I did exactly this on my turbo integra last year . It works perfectly and the tune should remain identical . Mine was spot on at the dyno .
Great! It Good To Know Someone did it already With No Problems... I Was Making Sure Since I Was Told I Needed To Retune By a Shop.... Thanx....
