Smanager & speed-sensor issue - reading incorrect VSS sp
OTT
Post by OTT »
Vehicle: 1998 Honda CIvic Type-R EK9, Turbocharged fully-built B16a, Gm solenoid for boost control!
vehicle is a japanese import and I have fitted a speed converter just above the vss connector to convert the speed signal from KPH to MPH
When Im doing 40mph its reading approx 20-25mph
Is there a way of reclibrating this sensor signal via Hondata?
my concern is the fact it thinks im in a lower gear than I am! and Id really like to have this setup ready for a competition next weekend.
You should not use a converter. All transmissions produce the same 4 pulse per wheel revolution signal. You just need to use a Cluster that reads in MPH for that vehicle.
OTT
Post by OTT »
Spunkster wrote:You should not use a converter. All transmissions produce the same 4 pulse per wheel revolution signal. You just need to use a Cluster that reads in MPH for that vehicle.
i think im going to move the converter to after the ecu splice. I cant get rid of the EK9 dash, dude its too nice to switch-out like carbon fibre effect. :shock:
