Which igntion should i use
DOHCAccord
Post by DOHCAccord »
I run a turbo h23 in my 97 accord. I have run the msd 6a and now am running the stock honda ignition. Im just curious as to which igntion system hondata and all the members recommend. I run the car to maybe 6600 rpm. thank you for your input.
Stock ignition is best and can be used in high horsepower forced induction as well.
hybridcivicls-t
Post by hybridcivicls-t »
Spunkster wrote:Stock ignition is best and can be used in high horsepower forced induction as well.
very true plus some of the aftermarket ignitions have really bad interference with hondata.
while ive had hondata from mid 400hp cars to high 2's still use stock ignition, and ngk plug wires-or stock oem wires
jew
Post by jew »
stock ftw. i had nothing but problems with msd ignition and hondata.
DOHCAccord
thank you.
