Check engine code 11?
rick_2002
Post by rick_2002 »
I have a 94 hatch with a 2.0 B18c1 84mm Bore LS crank on a Garrett GT35R S300 every once in a while I get a check engine and the code i get is 11. some one said it was a temperature warning... it sound like it can be right because it happens when i rip thru the gears or when i turn of the car and the turbo timer stays when i hoop back in the car after turning it off i get the check engine once i the fan kicks in i turn the car off then back on and its gone....the car runs strong regardless...any one have any ideas what it is?
V6<2>V8
how are you checking this code?
rick_2002
Post by rick_2002 »
Spunkster wrote:how are you checking this code?
thru the plug on the passenger side...
V6<2>V8
You have an s300...use it to datalog and check the error codes.
