Type S ITR reflash DRL light flashing
deanob
Post by deanob »
Hey guys, I've been running an ITR #4 reflash with supporting mods for a while now. I reset my ECU recently and now when I go past 7k+ RPM my DRL light begins to flash (Canadian car).
This is the first time seeing this... anyone have an idea? I doubt its a shift light as it just started to happen now. Maybe knock??
The ecu has nothing to do with your daytime running lights.
deanob
Post by deanob »
I figured as much as the DRL is relay / fuse based. Does the reflash have any kind of instrument flash code embedded? Just want to make sure it's not a warning of any kind. Can't seem to find much info on this with searching...
You'll need to contact your Honda dealer for help with this.
