missing complete dates when exporting a log (CSV)
kistian
Post by kistian »
I have this problem, I need to export the datalogs for personal use and precision comparsion
in the case of the MAP, it's exported in SI units (in bars, for me it's all right) but it only takes 2 decimal and the MAP sensor gets 3 for the datalog
this is an example of a line:
693,14.750000,1415,19.0,1.01,98.4,100.00,0,0,9.66,-3,41,95,0.86,0.85,0.00,0.00,0,13.70,14.5,4.12,0,3,0.50
the bolded value is the MAP value
it's possible to solve it?
a better solution (but expensive for hondata) is a configuration for the sensors to export, where the user can choose the sensors values to export and the precision in decimals
thanks for your time
The precision has been increased to 3 decimal places for the MAP sensor.
Making a user configurable export is probably not going to be too high on the work list. Making ad-hoc changes to the variables and precision is fairly easy, so if there are more minor changes like above then request these now.
kistian
Post by kistian »
no more changes about that I need, but in the 1.2.8, the latest version I've seen, the 3 decimal don't appear and I don't seen a newer beta in the forum
I only made the change yesterday - You'll have to wait until the next beta version.
kistian
Post by kistian »
ok, no problem
thanks for all
